Need help with my 5.3L lm7
Thanks.
My truck was recently throwing lean on both banks due to a giant crack in one of the stock air silencers, so I disconnected the intake and bypassed the silencer.
Check for vacuum leaks, check for correct fuel pressure.
I had lean 0171 and 0174 codes for a year and it turned out I needed new fuel pump and new intake manifold gasket. I suspect the fuel pump swap on a Tahoe is a B**** and a half. O2 sensors are still original, No vacuum leak, and fuel Px correct, original O2's still work just fine. I also had a recently replaced FPR so that took that out of the troubleshoot for me.
If it is the IMG and you do the intake manifold gasket yourself be sure to post a pic of how dirty the top of your motor is, the before and afters are fun. It took me about 6 hours to fully clean mine.
Thanks guys appreciate the help
You don't want to see mine, dude who owned it before me put a 3in body lift on the truck. It's too easy for stuff to get into the engine bay. If I hit a puddle while turning the bay gets mudded up lol.
As for my codes, they're back. But only on occasion. I'll probably just clear them until the weather breaks and pull the intake and throw new intake gaskets in it, seeing as though it's a pretty common problem.
