horsepower vs fuel
If this is an off road only vehicle, can timing be kept where it is or even added some with E85 ? Would it hurt or help horsepower ? The fuel system can support the fuel flow, injectors could support it... found a good source for it locally ... but since this isn't a blown application is there any real advantages ?
E85 does seem to run cleaner on the plugs....
Im pretty sure from experimenting that even thought it can handle more compression, diesel has less "pop" than gasoline and makes less flame speed (horsepower), but obviously more duration... not sure about ethanol.....
