P0300 after LT header install
Old Mar 8, 2016 | 02:04 AM
LBC_CALI's Avatar
Default P0300 after LT header install
i picked up my trans am after getting headers installed i checked my check engine and it was P0300. The O2 sensors arent plugged in since the O2 Sensor Extension was missing i just ordered new ones could that be the cause
Old Mar 8, 2016 | 06:20 AM
vettenuts's Avatar
I would get the O2's connected first then see if the code continues. I also wouldn't run the car without the O2's.
Old Mar 8, 2016 | 09:42 AM
joecar's Avatar
Also check for damaged spark plugs (cracked ceramic).
Old Mar 9, 2016 | 09:20 AM
Chevy406's Avatar
Joecar with the good advice (again).
If you have access to a data logger you can scan the misfire by cylinder and help narrow down which cylinder to check
