Built 5.3 issues
Old Mar 15, 2016 | 07:58 AM
bbowerman's Avatar
Default Built 5.3 issues
Hi guys I have a 5.3 with flat tops ported and polished heads MLS heads gaskets head and main studs. Cam is .561/.578 222/225. 112lsa.
The intake valves went from 1.8" to 2.05"
Getting 34# injectors or 36# on the fence now. But with 34# Bosch red tops we can't get it tuned any suggestions? Cam surely isnt to big for 10.5 compression ratio. My ls1 has .621 lift and runs fine.
Old Mar 15, 2016 | 08:11 AM
gagliano7's Avatar
Probably don't have the proper injector data for you injectors. If that isn't correct you will be chasing your tail.
Old Mar 15, 2016 | 11:21 AM
bbowerman's Avatar
It's about to get ls3 pullouts
Old Mar 16, 2016 | 03:35 PM
indirocz28's Avatar
Run the numbers and make sure you have the correct bosh red tops. There were some being sold as the 34# injectors some years back, and turns out they were only in the lower to mid 20's off of some 4cyl car from the early 90's.
Not saying this is your issue, but worth a double check if you bought them used.
Also, may want to verify that you're using the correct impedance injectors.
Old Mar 16, 2016 | 11:27 PM
Mercier's Avatar
My go-to for affordable 40-ish lb injectors is 12613412 flex fuel truck injectors. Injector data is out there, they are cheap(I've bought whole new take-off sets for $50), and they worked fantastic on a cammed LS2 I ran for a year. Flex injectors actually flow a lot with gas because they have to be able to run E85 which is less power dense and requires more volume. Maybe the LS3s are cheap too. Weren't when I was in the market.
Old Mar 19, 2016 | 12:17 AM
bbowerman's Avatar
Thanks for the replies looking into those injectors already got rid of the Bosch injectors now.
Old Mar 19, 2016 | 11:57 PM
bbowerman's Avatar
Just bought a full set of those gonna give that a try
