Flex fuel Silverado
If you have a flex fuel sensor and it is connected to the ECM then the ECM will adjust fuel and ignition timing according to the ethanol content measured in your fuel. So you do not have to change the tune based on different percentages of ethanol, but you should adjust the tune as necessary for maximum power.
