Ecu/tcm ccompatability questions
I currently have a ls1 engine with a 4l60e trans in my 74 camaro. I am using the ..411 ecu custom tuned with hp tuners to control both the engine and trans.
The new project is a 70 camaro. I have an ls3 with a tr6060 manual trans lift out from of a 2010 camaro. The ecu is a E38 and no tcm.
I want to do a tranny swap on the two motors. The tr6060 trans will go on the ls1 and i want the 4l60e to go on the ls3.
Questions:
ls3/4l60E: I need a tcm to mate with the e38 ecu. Do I go with a gm part or aftermarket. What tcm's are compatibility. What additional wiring harnesses are required. Am I missing any other needs.
ls1/tr6060: I have the engine controller and I don't believe I need a tcm but I have to have some kind of harness to the trans for vss and monitoring that is compatible with the 0411 ecu. What do I need to make this work. Again, am I missing anything else.
Please help!!!
https://ls1tech.com/forums/conversio...l92-4l60e.html
