Tuner sugestion
Old Apr 5, 2016 | 02:55 PM
Steve Cox's Avatar
Question Tuner sugestion
I do not want to go with something like the HP tuners as the only mod I plan is the GM hot cam. I do not think I would be able to use it and would probable blow something up
Do not have a dyno tuner in the area, Closest is 250 miles away.
So looking at a hand held. What one has the most adjustment? Add or remove fuel, Pull back spark, change fans, change KR, remove rear 02.
Also will the intune, Trinity and intune do the same thing tuning wise? I have Dash Command and AutoE pro for monitoring
BTW, I am at 6000 feet and the best gas we can get is 91 with 10 ethanol. And I would be surprised if it is actually 91
Old Apr 5, 2016 | 05:28 PM
2xLS1's Avatar
No hand held tuner is going to do what you need.Especially if the car is an auto with a Hot Cam. None will turn of DTC codes. Some hand helds can have custom tunes with what you need loaded into them but nothing off the shelf will. You would be better off sending the PCM to someone like LSX Power Tuning. Or you could buy HP Tuners and have LSX Power Tuning send you files to flash with it. It is easier to fine tune it that way remotely.
Old Apr 5, 2016 | 05:29 PM
Steve Cox's Avatar
It is a M6
