Exhaust Valve Question
Old Apr 15, 2016 | 10:52 AM
ItDoRun's Avatar
Default Exhaust Valve Question
What would cause my #2 header tube to be running approximately 100 degrees cooler than the other tubes. Thought I had an issue with the valve not opening so I pulled the valve cover and spun the engine over. All rocker arms are moving like they should. Maybe a fuel issue on that cylinder?
Engine is an iron block 6.0L with stock LS3 heads and a cam (.629/.612, 228/236, 112LSA)
Old Apr 15, 2016 | 11:19 AM
KCS's Avatar
KCS
Moderator
Any codes or symptoms making it a problem? EGT's often vary, I don't know if 100 degrees is normal but if it isn't throwing codes or causing a loss of power, I wouldn't worry about it.
Old Apr 19, 2016 | 01:16 PM
gagliano7's Avatar
Bad coil.
Old Apr 23, 2016 | 06:55 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Bad coil or a bad injector. I had this happen to me on Geoff's dyno before. I had an injector not firing at all.
Old Apr 23, 2016 | 06:15 PM
Old Geezer's Avatar
Plugs say???
Old Apr 23, 2016 | 09:45 PM
kingtal0n's Avatar
check plugs and compression
Old Apr 24, 2016 | 11:35 AM
joecar's Avatar
+3 what do plugs show...?
