Adding timing
Ignition timing is the point in the crankshaft rotation when the ECM triggers the coil to send voltage to the sparkplug. Most often this ignition timing point will be a certain number of degrees before top dead center on the compression stroke. It takes some amount of time for the flame front to extend from the spark plug across the combustion chamber. At slower engine speeds you don't need as much ignition advance (advance is a way of saying degrees before top dead center) as you will need with faster engine speed.
A typical LS1 engine will idle with 15° - 20° ignition advance and make best power at 28° to 30° advance. With the early LS engines, the ECM limited ignition advance in order to prevent detonation at high ambient temperatures, high loads, poor fuel quality. For a performance application where the user is willing to use premium gas the ECM can be re-calibrated to add more ignition timing which in turn increases power up to a point.
