ls3/th400 stalling issue
Old Apr 20, 2016 | 04:18 PM
dtes's Avatar
Default ls3/th400 stalling issue
hoping someone can shed some light on this annoying problem.
its a new ls3 running the e67 controller mated to a th400 with 2800rpm stall torque converter.
when warm and shifting from drive to reverse or vice versa the engine keeps stalling.
is the controller looking for a shift signal ect but not getting it ?
this is the engine in question
http://www.partsworldperformance.com...ngine-19301360
Old Apr 20, 2016 | 04:57 PM
LSX Power Tuning's Avatar
The problem is the ECM is programmed as a manual so its not looking for a auto transmission. Since the ECM doesnt see the trans or no your changing gears its no adjusting the idle like it would in a factory auto. You have to adjust at a minimum the idle, idle airflow, and timing tables to get it to work.
Old Apr 20, 2016 | 05:13 PM
dtes's Avatar
thanks for your reply, any tips ? i have hp tuners.
the people here in the uk are useless for aftersales tech.
may i add its perfect until it get to operating temps and then acts up
Old Apr 20, 2016 | 05:14 PM
dtes's Avatar
would it be possible to tell it that its an auto and the supply shift signals via microswitches and the sidewinder shifter ?
Old Apr 20, 2016 | 06:05 PM
If you try to tell it there is an auto it will look for a TCM and open a whole new can of worms.
If it works cold and not when at temp I would look at your idle and idle airflow tables and add some air in at operating temp. As the engine is getting warmer the ecm adds less idle air.
