Oil pressure through obd2.
I've got an '05 lq4 with the stock harness modified for standalone. It's the Blue/Green harness-ECU and DBW if that matters.
I want to be able to eliminate as many gauges as possible and use an iPad or Nexus tablet for a display.
I havent done it with oil pressure personally but thats how I would log transmission temps years ago.
Is yours was deleted from the harness, install new PCM pins as follows:
PCM PIN Sensor Plug Blue 63 - Pin 1 (black) Blue 7 - Pin 2 (grey) Green 58 - Pin 3 (Tan/wht)
After that you can use a scanner to read oil pressure.
- Y-car: already enabled in System segment.
- F-car: needs to be enabled in System segment (platform, feature).
- Truck: depends on price/trim, can be as either of above.
In either case, PCM connector has to be pinned (refer to 2002 Y-car wiring diagram).
