HPT RTT issue
Old May 3, 2016 | 06:54 PM
NitroFumesAteMyBrain's Avatar
Default HPT RTT issue
Once i select the RTT OS for my tuneup i save to another name and write entire. Then selected engine/general and selected ve-spark-maf then write calibration. Once thats done i close vcm editor and open vcm scanner, key on, connect, start scanning.....no lightning wrench.....am i missing something? Slso if i view the tune on vcm editor and i click on OS the window is blank but like earlier it still shows the rtt option with ve-spark-maf selected like it took. Any ideas?
Old May 3, 2016 | 07:25 PM
Shouldnt it show rtt code applied in the OS window?
Old May 3, 2016 | 07:26 PM
As i would assume now only my rtt tunes will write to the pcm, i assume i would have to write entire to go back to the standard OS for the std tunes
Old May 3, 2016 | 07:49 PM
2xLS1's Avatar
If you are using V3.0 it was disabled. They re enabled it in V3.1 beta.
Old May 3, 2016 | 07:50 PM
Errrrrr, thanks....i am
Old May 3, 2016 | 07:51 PM
Seems like 3.0 is a basket case
