tune locked? speed density using maf?
here are a few questions i have if someone would be so kindly to answer:
1) what all does this tuner lock do? does it not show all tables that can be edited or just not allow me change any tables?
2)why would the operating system be locked?
3)the operating system shows 3 bar speed density, so why will the car not run with the maf unplugged? I am also getting a p0101 dtc
4)the car is running very rich on decel, sometimes between 11-12:1. This leads to loading up and popping after i get back in the throttle. Any ideas here, i dont remember it doing this last year?
5)lastly i took some data logs the other day and noticed that my map sensor is maxed out at 105 kpa on the logs and will not read higher. I have a 3 bar map sensor so why is this happening?
i can post the tune file and data logs if needed.
thanks for any replies
also 2 other things:
1)i still have my factory o2 sensors in place, is there any reason why i shouldnt enable closed loop operation and enable short term fuel trims?
2)is it normal for the car to go very rich on spool up even though im not really seeing boost (1-2psi), is this just a trade off of being safe if the turbo would spool too fast and the fueling wouldnt be there? Its just kind of annoying if im driving around not gettting into boost but just on the edge where it starts dumping fuel in.
