Heads going on....Will it change tune?
Old Jun 16, 2004 | 09:19 PM
John02SS's Avatar
Default Heads going on....Will it change tune?
I will be installing a set of AS 5.3 heads next month and want to see how much the tuning will be affected by the heads. Anything I should expect? Thanks for the info.
John
Old Jun 16, 2004 | 10:14 PM
ataylors's Avatar
it should be changed a lot, it may very well run fine but you will for sure be leaving HP on the table.
Old Jun 17, 2004 | 04:28 AM
Billiumss's Avatar
You'll get a little leaner up top with the additional air coming in.
