Shift light
Old May 29, 2016 | 04:42 PM
Adrian Bendich's Avatar
Default Shift light
Was looking to hook up my autometer pro shift lite (5340) from what I understand I hook 12v red and black and green feed wire to white wire on pcm pin #48 for tach feed but when I do I get nothing I'm told that once the pcm has been custom tuned or flashed you loose the signal from white wire...is there a n other way to hook this light up? Also have a lingenfelter lcn 2000 would it be possible to get a signal from the launch control box??
Old May 29, 2016 | 06:06 PM
2xLS1's Avatar
Not true about losing tach signal after tuning. Is the shift light set up for 4 cyl mode? It needs to be.
Old May 30, 2016 | 02:32 AM
Thanks for the info thw light has 4 6 and8 I'll give it a try I have it on 8cyl
