No throttle
Old Jun 4, 2016 | 09:07 AM
trobert3's Avatar
Default No throttle
Swapped drivetrain from 09 Silverado 5.3 with 6L80 trans into 78 nova, dod,vvt delete. Car has been running over a year, took it out Memorial Day and noticed it won't shift out of 4th gear. So I headed home about 6 blocks from home no throttle but engine still running, finely make it home. Disconnect battery for a few minutes to reset computer, reattach battery and now throttle responds drive around block and same thing again no throttle. So I check for codes and PO641 open circuit, so I check grounds and harness nothing loose no broken wires also swapped throttle body with same results after a short drive.
Old Jun 6, 2016 | 12:19 AM
LLLosingit's Avatar
Might be the pedal itself, Had the pedal go bad in my commercial vehicle 3x now. I know it's not the same vehicle but they do go bad. Since it's swap vehicle I would double check the wiring to it also.
