Boost Ref. Regulator Tuning
Old Jun 9, 2016 | 10:49 AM
MikeD.'s Avatar
Default Boost Ref. Regulator Tuning
2006 GMC Sierra that I am finishing up converting to return style fuel system, with a BRFR. I know I need to change the injector data around but I'm just not 100% what and where. Any help?
Old Jun 10, 2016 | 04:37 PM
ddnspider's Avatar
The injector flow rate is now constant across instead of being sloped.
Old Jun 15, 2016 | 01:18 AM
joecar's Avatar
You have to measure rail pressure with the reference hose removed, and set the FPR to 58 psi.
And then remember to reconnect the reference hose.
And like ddnspider said, your IFR table will now be flat, and also your injector offset voltage table (the 0 kPa values copied all across).
