Pnp range sensor wiring/starter relay Help!!!
Old Jun 14, 2016 | 07:54 PM
ls71nova's Avatar
Default Pnp range sensor wiring/starter relay Help!!!
posted this a few days ago in conversions and hybrids I am currently doing a 5.3 and 4l60E swap in a 93 c1500 and trying to finish up the wiring I want to use the factory mounted pnp/ nss switch because I will already be wiring the trucks reverse lights to it. I am using a relay between the pnp and the starter and currently have it wired as follows #30 to purple wire from the ignition switch, #87 purple wire to starter solenoid, #86 to the lt green wire for park/neutral output, and #85 ground wanted to make sure it is right before I crank it over or if needs to be wired to the relay differently idk haven't had much luck finding any good information on this thanks
