Can not run in SD mode
Old Jun 26, 2016 | 05:25 PM
twistiert's Avatar
Default Can not run in SD mode
Hey Guys, I can not figure out why my car won't run in SD mode. I did everything that HPTuners posted to do. I even copied some from another tune. The car will turn over and kind of start but then it shuts off right away. I attached the file I'm working off of. The car is an 02 camaro MT with ls6 intake manifold, 42 lbs injectors, SLP lid, G5X4 cam, Comp Chromoly push rods, BTR 660 dual valve springs, stock 1 bar MAP sensor (but I did pick the 3 bar license for the future. Any help will be appreciated.
File Type: hpt
Old Jun 26, 2016 | 06:42 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Your VE table is screwed. The cranking VE table looks pretty normal, which would explain why it will try to fire up, but there is no way it will run on that main VE table. Also, are you sure you have the right IFR values? BTW, If you are trying to run a 1bar MAP on that 3bar VE table, it will make it even more difficult to get the numbers right. I would suggest starting back with a 1bar VE table populated with sane numbers and go from there.
Old Jun 27, 2016 | 11:24 AM
twistiert's Avatar
Thank you, do you happen to know what the IFR values would be for 42lbs injectors?
