0411 PCM and wiring harness question.
The 99 does not have a wire harness nor PCM. I know my 98 stuff will not work without modification and that's fine. I plan on selling my car as a roller with the harness and computer with it.
I want to know if the engine harness I get from a 99-2002 fbody has to be a 6 speed harness or does it matter at all?
Also i need to verify that the 0411 computer can be from a truck/auto/or whatever and it shouldnt matter as long as its an 0411 computer correct?
What harnesses will work.
Both of my cars are M6 cars.
Everything was swapped in the tune. Everything works except the speedometer. I changed the vss sensor twice.
Hptuners doesn't show speed. I swapped clusters 4 times.
I did run a jumper wires from the sensor to the pcm. I was about to tap into 20 and 21 on the RED connector but noticed the right colors and the right position is on the BLUE harness.
Should I tap the BLUE 20 and 21 which are purplet white and green/black?
Or stick with the diagram and tap the two on the RED connector? Wrong colors for 20 and 21.
99 pcm to 0411 pcm
