Speed density component questions
Old Jul 4, 2016 | 11:17 PM
gwtt's Avatar
Default Speed density component questions
Hey all, I am building a 5.3 with twin turbo setup going into a 1975 C10 pickup. I have been working on the Harness deleting the secondary oxygen sensors, Emissions, and other junk that I will not be using. I know if I go speed density I will be deleting the MAF. However, my 2002 5.3 the MAF also holds the IAT sensor in the same housing. Do most guys buy a separate IAT and wire it in or use the existing MAF housing and gut it leaving the IAT in? I've thought about leaving the MAF setup in but from what I have read in the forum sticky's that Speed Density will be my best option. I want to run between 8-15 PSI depending on tuning which I plan to have professionally done. I am going to Keep stock 862 heads and have larger valves put in the intake, a cam and spring upgrade. I have already purchased a 102mm Throttle body and intake to match (Holley Sniper/ symbolic luxury performance) Still need to purchase injectors (I have a A1000 pump and boost referenced regulator) I have a Map sensor out of a 2005 Grand Prix Supercharged PN 12580698. I was looking at using a CX racing partial kit from either their GTO or LSX A body chevelle setup and fab the rest of the cold side from there.
