Please help. Cam sensor problems from LS6 to LS2 swap
Now, I know I have the correct cam sprocket. I even removed all my second guessing doubt when I took the sensor out and double checked with a scope. So that's not the problem.
The. I threw a new cam sensor at it part number 12591720
Now I did all the searching possible to help with this and did the "wire swap" deal which you need to do apparently with the extension harness. So currently it is wired the way I drew it out in the picture.
Lastly I did a continuity test on all wires and everything checks out fine. At this point I'm completely lost as to why I'm failing. Any help and expert knowledge is much appreciated!
