HP e85 tune anyone?
Old Aug 9, 2016 | 06:30 AM
95ls1sb's Avatar
Default HP e85 tune anyone?
Does anyone have a base e85 map. I will look at the map and compare to what I have. Im wanting to learn the tuning difference between the two for future upgrade to e85.
Im speed density now and N/A but will be switching to e85 prior to my turbo install in the fall.
2000 5.3 truck lower and red/blue pcm btw.
Anyone?
Old Aug 10, 2016 | 04:28 AM
Brando5641's Avatar
You referring to the VE table?
Look at a stock flex fuel truck if that's all you want to see.
Old Aug 10, 2016 | 11:06 AM
subeone's Avatar
just change the stoich...unless you are using a ff sensor... then you have to populate some other flex tables
