Good one minute, bad the next
Since then I have installed a 2800 stall converter and built 4l60e. I now am noticing that the car has a qwerk. One time I will go WOT and the car will break loose and scream like hell. I can come to a stop and go to WOT and it will barely gets out of its own way. Maybe chirp the tires. Also I noticed if you try to power brake the car it will start to spin and then it will almost die as if you let out of the throttle even tho its still sitting at WOT or near WOT.
I don't know if this is a TPS issue or a traction control or a sensor I am unaware, or the tune perhaps?
The 4 channel is disabled on the car. One of the wheel sensors literally broke in half on the rear axle and gave up trying to replace it. I haven't been able to locate one anywhere. So my dash reads abs inop and etc off all the time.
I have checked my tps voltage and it comes in a .39v at 0% throttle and 4.29v at WOT. I now have HP tuners and can look at what my ecm is set at even tho i'm not 100% sure what it all is. (I am still learning)
Any help, pointers, things to look for or check, things in the tune i should check? Thank you for your time and any information!
What you can do is find a stock 99 A4 file and run a comparison of all that has been changed. If something looks funky, post up some screen shots and someone will chime in.
I will definitely post up pics of any differences between a stock ecm and mine once I get home and can download an original.
Next plug the IAC back and do a TPS reset.
A TPS triggering codes causes a lot of erratic problems specially on A4 cars.
P0463 Fuel Level Sensor A circuit high (Pending, Current)
P1626 (Current)
P1637 (Current, History)
I tried to dig a little on the 1637 and a couple forum posts I read this could be a ground or ECM issue? Am I on the right path or am I misreading what information I have found. I'm going to start going over and cleaning as many power and ground connections as I can find.
