HP Tuners Filtering
[50090.156]>10%
[50090.156]<10%
Edit for further clarification.
If you want to figure out some function, use the variable wizard. From the scanner, Tools > Math Parameters. Click on a blank User Math variable, which opens the Variable Wizard. From here you can select the variable you're looking for (in this case TPS), and it'll give you the data you're looking for. You'll have to add your own filtering to the PID, like the >10% note above, but that's the basics of it.
