Gen4 tuning help
Old Sep 27, 2016 | 06:48 PM
eaglegoat's Avatar
You need to make sure your TC isn't locked at idle. If it is it's loading the engine too much. Then you need to redo/confirm your idle air and timing. The adaptive idle isn't causing the issue. It's trying to respond to the issue.
