Questions about tuning MS3Pro/using tunerstudio?
Old Oct 17, 2016 | 10:32 AM
OEF14vette's Avatar
Default Questions about tuning MS3Pro/using tunerstudio?
So I have an MS3Pro on my car and I just fired it this weekend and did a datalog of the first start but I think I have something not right it idles but the AFR seemed really lean. it came with a stock 4.8 startup tune and I followed the directions changing the displacement and calibrating my sensors but I also have a cam and 60 lb injectors so I am sure it needs help. So long story short is their any known good tuners that I can bounce questions/datalogs off or anyone that has a near identical build with a "better" base tune to go off? thanks guys
Old Oct 17, 2016 | 06:28 PM
93camaro_zzz's Avatar
The ms3pro has autotune capabilities. So it should be trying to correct to your target value at all times. If it is not doing that, then yes, I think something was not set up right. Have you entered the correct injector data?
