1998 stock PCM, will not start NEED HELP!!
I left the battery disconnected for 2 hours as well, nothing.
Today, I decided to do a compression test just to make sure I didnt bend any valves and all cylinders were between 165-190.
The car has spark on #1 cylinder (which I was told the crank trigger controls spark) and #3 (which I was told the cam sensor controls spark for 2-8), fuel pump primes up, and with the schrader valve depressed squirts fuel everywhere (cant find my damn fuel rail pressure gauge).
I checked the PCM ground on the harness using my mulitmeter, went positive side of battery to pin 72 and 76 and it showed 12v. When I turn key on, the injector plug shows 6ish volts and drops to 4ish volts when cranking if I use my mulimeter on just the injector plug. If I go pink wire on plug to chassis ground key on, i get 12v. Still nothing, I cant find a fuse popped, the PCM connects to a scan tool, which has nothing major in the code files.
Im lost, and I am hoping the LS1TECH community can help me out.
I got the car built as it is, which up til now has been a lot of fun.
1998 Trans Am
Stock engine
Hooker LT, ORY
Borla cat back
TCI Street fighter 4L60E
3500 stall
BMR torque arm
Tubular rear control arms w/ relocation brackets
Moser 9" 3.90 gears, 35 spline axles, Detroit Locker
295/55-15 Mickey Thompsons ET Street S/S on Race Star wheels skinnies up front with M/T tires
INT CONTROL MODULE Memory Check Sum Error
According to the internet, the PCM is bad.
Funny thing is, I can get data streaming from the OBD2 fine, all sensors are present, shows cranking RPM's, shows timing being added, all the gauge cluster works.
Maybe it burned up the injector driver??
If that doesn't fix it, then a bad PCM is very likely.
Unfortunately 1998 PCMs have become rare and therefore expensive.
If the '98 PCM is unobtainable you could repin the PCM connectors to use a '02 "411" PCM.
Hopefully it won't come to that.
I sprayed some carb cleaner directly into the intake and the car, cranked it over and it stumbled, so I know its capable of running. The injectors are simply not firing.
I went ahead and checked the 2 PCM grounds on the blue plug, and they are showing continuity. Im seriously lost with this car. From my intense internet searches, I have found nothing concrete.
I realize the PCM grounds the injector to open it, and I know the 12v source is good, but the damn injectors do nothing while cranking, either bank. The INJ-1 and INJ-2 fuses are good and seeing 12v.
My buddy just dealt with the same thing in his 98 z28.
https://ls1tech.com/forums/pcm-diagn...-security.html
Not sure what you plan on trying.
Best bet is an 0411 upgrade. You’ll have to repin it, but so long as you label everything it’s not terribly difficult. You’ll also need to lengthen some wires. Good luck.
Regards,
