dummy needs help getting 98 to idle
Old Jun 22, 2004 | 02:31 PM
smeshey's Avatar
Default dummy needs help getting 98 to idle
like it says I am clueless on how to get the car to idle. It has ported heads ls6 intake T1 cam stock TB but I have an slp sitting around if it would help. I have HP tuner just no clue on how to get it to idle. Car will idle after about 3 minutes of driving. just wont idle on start-up. HELP PLEASE thanks Scott
Old Jun 22, 2004 | 04:26 PM
P Mack's Avatar
First adjust your idle stop screw until your iac steps come down. I recommend taking the screw out and putting it back in from the top. Then reset your throttle position sensor as shown here https://ls1tech.com/forums/pcm-diagnostics-tuning/177230-stop-drilling-those-tbs-fix-stalling-without-computer-tuning.html. If you still have problems with cold starts try changing the ve tables as shown herehttp://www.ls1tuning.com/iboard/index.php?showtopic=9.
Old Jun 22, 2004 | 08:57 PM
ataylors's Avatar
Add timing also at 1200 rpm and below, just a couple of degrees
Old Jun 22, 2004 | 11:08 PM
Another_User's Avatar
I did 2 degrees on all rpms 1200 and below. It smoothed well into my table too. I saw other people who did the same thing.
Old Jun 22, 2004 | 11:29 PM
smeshey's Avatar
Default Thanks
thanks alot guys i'll try this friday Got to love LS1TECH everyone is willing to help! Scott
