Speedometer not correct, months after being correct
Old Nov 27, 2016 | 06:40 PM
zapp109's Avatar
Default Speedometer not correct, months after being correct
So at start of summer I put 3:73 gears into my wife's car and changed the tune to 3:73 gears. It worked perfectly for months. Recently had her tell me speedometer is off and car is shifting weird. I just pulled the tune in the car and nothing has changed??? Basically if your doing 65 mph speedo says 75ish. Should I try just reloading tune?
Old Nov 28, 2016 | 05:48 PM
rpturbo's Avatar
Probably a "bad" ish speed sensor. That would be my 1st guess. Basing that on the weird shifting and the speedo also being off. I guess blowing the tune in is easier, but if nothing else has changed, something must be causing it.
Old Nov 28, 2016 | 07:06 PM
zapp109's Avatar
Good thought on speed sensor. Later this week I'll reload the tune. If it doesn't fix it I'll grab a VSS and hopefully it fixes it.
