Boost controller- hp tuners
Old Dec 11, 2016 | 09:33 AM
aaron101m's Avatar
Default Boost controller- hp tuners
Is there any boost controller on the market that is compatible with hp tuners directly?
How can you tune for the boost controller so that your computer automatically knows what to do when you turn up or down the boost?
I am New to fi tuning
Old Dec 11, 2016 | 01:33 PM
JoeNova's Avatar
Restricted User
I don't understand.
You don't tune for a single boost level. You tune for an entire range. Then you can adjust the boost controller how you want and not have to change the tune at all.
Old Dec 11, 2016 | 01:43 PM
AgFormula02's Avatar
The pcm will add fuel based on the VE table, PE table, or Boost Enrichment table. (Or all of the above, and even the MAF, but I stick to Spoed Density)
It is all about air flow. The boost controller changes how much max air goes in, the PCM reacts to the extra air at all levels.
FI tuning is not something you want to guess at. Screw ups can get expensive fast.
I recommend you do some reading on tuning and how PCMs work , then play around on mild NA set ups - or stock - to get hands on knowledge of how things work.
PS: Invest in a good wideband and a fuel pressure gauge.
