OBD2 blowing fuses
Also the tachometer intermittently works. Out of 15 times it didn't work twice at startup but began working after driving for a few miles. I figured it was voltage related or a grounding issue.
You could have a short to ground in the wiring harness or you could have a bad cluster or module. Chryslers are really bad about it but GM not as much.
First thing I would do is get a wiring diagram for everything on that circuit and look for the most obvious things.
It's also possible that a wire for that circuit has burned or "melted" into another circuit.
I had a Toyota SUV that kept blowing the wiper motor fuse. After some searching I found the fuel pump was going bad and had melted the entire body harness and was grounding/shorting out the wiper motor circuit.
If you feel you are capable of finding the problem yourself with some help let me know. If you know it's over your head(which is fine, electric problems can be difficult" then take it to a competent shop.
Here shortly someone will be in here to tell you to swap out a bunch of parts till you find it....Waaaiiiiit for it.
Seriously though, shoot me a PM or keep us updated in this thread.
J
