58x to 24x
The crank sensors are not the same between the 24x and the 58x engines. Fairly certain even if you are using Megasquirt you want the correct sensor for the particular reluctor wheel you are using. The crank sensor connector is also different between the two so your harness might need changed.
Jason Haines
Product & Service Solutions LLC
www.proservsolutions.com
https://www.facebook.com/proserv/
