No throttle pedal after wot
Old Feb 1, 2017 | 03:12 PM
chevellepowered's Avatar
Default No throttle pedal after wot
2009 silverado
v6 to v8 swap , pretty straight forward plugged right into fuse box the engine harness .
driving normal is fine , after at stop sign and stomping it wot or more half throttle ., before it even comes up to high rpm itll loose the throttle , and ill have to let it glide over to side of street , key off wait few minutes then back to normal . It only happens here and there . not constant .
Truck is open loop , o2s turned off . Running maf . Any ideals . i could log a run and try that. Maybe faulty throttle body?
Old Feb 1, 2017 | 03:14 PM
Old Feb 2, 2017 | 09:49 AM
Mr442's Avatar
Default blue chevelle 5.3 turbo
Hey man I'm glad I finally found you I need to ask you a couple questions about the motor that was in with the single turbo
Old Feb 2, 2017 | 10:02 AM
aruss99's Avatar
I think posting the tune would be a good idea. My guess is it goes into limp mode when the expected airflow is greater than the actual calculated airflow. It is a common issue with speed density tuning. Hopefully someone more knowledgeable could chime in and explain better than I can
Old Feb 2, 2017 | 10:52 PM
JakeFusion's Avatar
Super Hulk Smash
Any codes?
Old Feb 6, 2017 | 10:12 AM
LT-4Play's Avatar
What throttle body is on the V8? Gold or silver throttle blade? I've heard of WOT issues when using the wrong one - I believe the correct throttle body for the 09+ cars is the gold blade. Just another thing to check out.
