New 402 Build
Old Mar 21, 2017 | 07:02 PM
mobileman's Avatar
Default New 402 Build
I know this is asked probably all the time but I want what's the best.
Build:
402 12-1
251/255 .678 .632 LS 112 ICL110
FRH Heads
ported Fast 102
Kooks 2in
54# injectors
NW 102 TB
370 Gear
4l80
Car has a direct port but am not going to spray over 200. I need to know maf or speed density tune. And What Maf if I go that route?
Old Mar 22, 2017 | 03:09 AM
Exidous's Avatar
Sounds like a max effort setup. That FAST 102 will hold you back up top.
Most will tell you to go SD. I run SD. MAF is more accurate at WOT. I can get the WB trace to match the commanded almost exactly with a MAF. With SD you'll get really close but never perfect. Usually waiver .1-.2 AFR from commanded. The more drastic the environmental swings the more beneficial a MAF becomes. Unless you have an aftermarket ECU that can do barometric reference then SD and Alpha-n can handle the environment better.
In the end, if you are road racing SD/alpha-n is the way to go. If you are drag racing and not boosted MAF is the way to go. A MAF doesn't react fast enough to really shine on the road course.
The 4" tube screened LS7 MAF sold by Texas Speed is one of the best options. You MUST run a screen on a 4" tube. If you don't you will be chasing tuning ghosts endlessly due to non-laminar flow. The lowest cell density is fine. This MAF/IAT combo can be used with an 24x (needs a harness) or 58x harness no problem. It's all in the tuning.
Old Mar 22, 2017 | 07:24 AM
Tuskyz28's Avatar
The heads.... cathedral port or rectangle port?
Small split on the duration for a healthy shot of juice.
Old Mar 23, 2017 | 06:06 AM
mobileman's Avatar
Its going to be drag raced and driven on the street here and there. Cathedral port heads. Thanks for the replies.
