Unsuccessful in finding LS2 injector data in gen3 ECM format
Old Mar 24, 2017 | 06:28 AM
codyvette's Avatar
Default Unsuccessful in finding LS2 injector data in gen3 ECM format
LS7 injectors information in a gen3 file was a snap. Now I need the same thing for a set of LS2 injectors and I can't seem to find an example I trust. The flow vs kpa is easy but the other 3 tables, not so much. Since they seem to be very similar to the LS7's, would the other three tables be the same?
clhannah25@yahoo.com is my email if someone has a tune with the info they would not mind sharing. Thanks
Old Mar 27, 2017 | 11:09 AM
codyvette's Avatar
Over 100 views and nothing?
Old Mar 28, 2017 | 12:14 AM
RonSSNova's Avatar
Here are a few I've gleaned from the net.
No guarantees these are correct.
I have them in my C5, and all I changed was the flow rate. I never changed the rest. At that time, 4 years ago I was just learning and didn't know I had the change all the tables.
That said, it runs perfect.
Anyway, here you go.
3.2 Smoothed MAF is my tune.
Ron
File Type: hpt
File Type: hpt
File Type: hpt
Old Mar 29, 2017 | 03:04 PM
codyvette's Avatar
Thanks a ton. Bad info is what I fear getting. I'll check it out.
