Lean code bank 2?
Old Mar 25, 2017 | 12:30 PM
Bmac89's Avatar
Default Lean code bank 2?
Well I've got an LS1 in my 64 nova. I had the check engine light come on twice. Showed lean condition bank 2. Autozone wanted to sell me intake gaskets. Well I've only got 1700 miles on them. I held off. Borrowed a buddies little scan tool to clear it. Well it came back on about 50 miles later. Got the scan tool out and cleared it again. This time I used the dashboard feature and seen the bank 2 sensor was staying at .44-.46 v. Bank 1 was moving around. Swapped sensors around and it did the same on bank 2 still. Checked plug ends and the wires going to the pins,continuity, on the ecm. Everything checked good. Guessing it's a ecm issue. Anybody else hear of this happening?
Old Mar 25, 2017 | 07:30 PM
2xLS1's Avatar
No, newer ECMs as a rule are very reliable. But then again who knows what you are using?
Old Mar 25, 2017 | 08:12 PM
sbcgenII's Avatar
Sounds like you have an exhaust leak or misfire on bank 2.
Old Mar 25, 2017 | 09:09 PM
Bmac89's Avatar
02 camaro ecm. It runs good...No misfires,exhaust leaks or anything. I talked to PSI to find out pin locations to check and all was good. Just got my ecm in today. Going to be the middle of they week before I get it re-flashed.
Old Mar 25, 2017 | 09:31 PM
Petrolhead575's Avatar
I had a very similar problem on my LS1 240SX, pinhole leak in the header collector.
