check engine light I have a code P0420 and I need help to get this fixed. |
Trouble Code P0420 - Catalytic Converter Inefficiency Bank 1 I assume your running O2 sims, right?? Looks like one might be bad |
Originally Posted by ataylors Trouble Code P0420 - Catalytic Converter Inefficiency Bank 1 I assume your running O2 sims, right?? Looks like one might be bad |
well if you want to be sure, swap them and see if you start throwing a code for the other side. |
Originally Posted by ataylors well if you want to be sure, swap them and see if you start throwing a code for the other side. |
If these o2 sims work the way they should I shouldn't have any problem passing emisions testing right? |
© 2024 MH Sub I, LLC dba Internet Brands
