ls2 controller 19166570 can bus lines
Old Mar 31, 2017 | 01:17 PM
mlc 67''s Avatar
Default ls2 controller 19166570 can bus lines
Anyone know if theres anything that can be done with a e67 controller that is not relaying info to tcm? Im using chevrolet performance engine kit 19166570 and transmission kit 19302405 , the engine and trans are from a 08 tbss. checked double checked all connections and pins, voltage dropped tested all can lines and grounds, engine ecm runs the engine and gauges perfectly and the numbers agree with the scan tool. But the tcm is not seeing anything from ecm on the laptop needless to say the transmission wont up shift. Even the engine temp reads -40. I had the original e67 ecm from the pullout so I plugged it into the harness I knew I wont be able to tell to much without the vats turned off but I was able to get the correct engine temp to tcm so that leads me to believe that my new ecm isn't working. Any help would be greatly appreciated thanks!!!
