MS3 1-wire oil pressure sensor
Old Apr 7, 2017 | 07:19 AM
Mark_NL's Avatar
Default MS3 1-wire oil pressure sensor
Hi! I'm looking for options to show the oil pressure on MS3. The stock oil pressure sensor has only one wire, is it possible to use this sensor with MS3 or do I need a 3-wire sensor?
Does anybody has the part numb. for a 3-wire sensor?
Old Apr 8, 2017 | 09:56 PM
space387's Avatar
you should be able to run the single wire sensor, as long as you have a ground to the block from MS3 it should function no different than any 2 wire sensor.
Old May 16, 2017 | 01:05 PM
acedeuce802's Avatar
The 1 wire sensor is likely a resistive sensor. Megasquirt is expecting a 0-5v input for the analog inputs. You'd need to pull the resistive signal up to 5v to make a voltage divider. Then you'd need to know the calibration. It is probably just easier to use a 0-5v sensor (aka 3 wire).
