Rev limit changed?
Old Apr 14, 2017 | 01:05 PM
SIXSPD's Avatar
Default Rev limit changed?
I just recently installed a micro shift light in the pillar defrost vent and there were only 3 wires green (tach), red (hot) and black (ground). I hooked the green to the 10 pin white wire where my NOS mini is tied into. got into the car and took it down the road. I had it set to 6700 since my ls1 383 stroker stops at 7k. I take off and rev limiter kicks it at 6500???????? what happend? the shift light shouldnt change my limiter. Any help guys?
Old May 5, 2017 | 05:00 PM
SIXSPD's Avatar
bumpity bump
Old May 5, 2017 | 05:22 PM
subeone's Avatar
whats your limiter in the tune set at
Old May 5, 2017 | 05:40 PM
2xLS1's Avatar
Tach will lag behind actual rpm. Especially in the lower gears. You need a data logging scanner to see what the actual rpm was. Also the PCM outputs a 4 cyl tach signal. Did you set up the shift light for a 4 cyl signal?
Old May 7, 2017 | 07:14 AM
Darth_V8r's Avatar
Moderator
**** my tach won't rev past 6400. I have to use HPT logs to see how high my RPM get
