afr% error help
Old Apr 20, 2017 | 08:27 PM
lkeller's Avatar
Default afr% error help
does anyone know why it will only plot cells up to 80kpa any thing past that it just plots a zero. its on a 2bar SD tune.
File Type: xml
ST Fuel Trim.Table.xml (784 Bytes, 63 views)
File Type: hpl
Old Apr 21, 2017 | 10:33 AM
RonSSNova's Avatar
I don't see a wideband in your log?
Old Apr 21, 2017 | 12:20 PM
lkeller's Avatar
dont have the wideband hooked up, trying tune the VE table with this
Old Apr 21, 2017 | 09:31 PM
RonSSNova's Avatar
AFR error compares your wideband reading against AFR commanded.
so you need a wideband to use the feature.
Trims read the error directly.
