Thinking of switching to EFI Live from HPT
Old Apr 29, 2017 | 08:27 PM
dlabooda's Avatar
Default Thinking of switching to EFI Live from HPT
I've got HP Tuners Pro and I like the software but I've got a Duramax Silverado that already has an EFI Live OS that I'd like to be able to tune as well. It seems like HPT is a little better for LS tuning but it's very lacking for diesels. Since my Chevelle is already tuned with HP Tuners would I have any issues if I switched to EFI? I know they can't read each other's files but would EFI Live be able to pull the data off of the PCM since it is using the stock operating system? The engine has been dyno tuned and I don't want to lose all of the adjustments.
Old Apr 30, 2017 | 08:17 AM
Pacer Racer's Avatar
As long as its not tuner locked or using a COS, you'd be good to go. I've used more then one tuning package on the same pcm several times, since some tuning packages do some thing better then others and there are some tables that one will access that other one will not and vis-versa.
Old Apr 30, 2017 | 02:45 PM
ddnspider's Avatar
I have used efi live and hpt both to tune cars...I compare it to apple vs. Andriod. Apple is hpt, very user friendly, but you can only change so much. Efilive is like Andriod in that you can mod and tweak everything exactly how you want it and the table structure has a ton of tables readily available. My preference is efilive.
Old Apr 30, 2017 | 03:35 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
HPT has stepped up their diesel game quite a bit! Esp with their new 3.x software. download some files off their tune repository and check em out.
Old Apr 30, 2017 | 03:56 PM
dlabooda's Avatar
Unless they add some sort of DSP switch capability, they're still way behind. The truck already has the custom OS so it's incompatible with HPT anyway.
