lq4 id850 ls9 cam issues
nd adjust my ve table but no matter what i do to it it wont stay running and with my trans at .0041 which is stock its stuck at 10.6 and smells like raw fuel. so my other question is how much it would mess it up haveing stock injection timing with the cam. im running the provided data that came with the injectors. the other issue is sometimes when i lean into the throttle it will spike to 17 to 18 afr and cut right off like the fuel was shut off which is obviously dangerous. so i will provide my tune and a log of the random spikes. any ideas are welcomed. i have tryed messing with so much stuff and im getting very irritated i cant figure it out. blue current.hpt deadly lean spots at end.hpl also i should add if i plug my stock narrow bands in it will find its way to a 14 to 15 afr idle but it also doesnt let my engine richen up for boost so i leave them unplugged.
