Logging desired idle airflow
Old May 12, 2017 | 10:00 PM
Cb2417's Avatar
Default Logging desired idle airflow
Hello everyone! I am new to tuning and have had a bit of success so far but also lots of frustration haha. While trying to run a scan and log my desired airflow ( I am using russ k's layout .xml) no values populate the columns under my ect header. The row axis of my table does not have grams/sec but maybe this is not needed? I do have both my editor and scanner using the same metric units. Other than this I don't know why my airflow chart is not logging at all. Any help at all would be greatly appreciated thanks
Old May 13, 2017 | 12:08 AM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
First off you have to have the desired pid in the primary table
Second the histogram has to be set up exactly like the editor graph you are correlating to. then youll have to select the pid to use. that should be it.
Old May 13, 2017 | 11:08 AM
Cb2417's Avatar
I do have the desired airflow in my channels as well as in my graphs. The table in the graphs I'm using has the same units as the one in my editor. Both are
Celsius for ect and g/s for airflow. Not sure what you mean by selecting the pid to use? Just click on the desired airflow channel when I start scanning? All of the layout I'm using is from Russ k's .xml charts graphs and channels. I start right from scratch and import only his files to my scanner.
Old May 13, 2017 | 05:18 PM
Cb2417's Avatar
Ok just as I suspected I was being a dumb rookie again hahaha. I changed my numbers for my ECT values in the column axis to match my editors table EXACTLY and BOOM! It works now. Thanks ws6store for the response
