surging low rpms
Old May 14, 2017 | 02:43 PM
fatcat91's Avatar
Default surging low rpms
I have LS3 in a 33 Ford Roadster. While cruising at low rpms and 30 to 40 mph it surges and jerks terribly. I have a GM drive by wire computer and harness from GM. Also, while cruising the highway at 55 to 60 mph I run into the same problem. It has a 4L70E transmission and 341 gears in the back. Any ideas what I can do to cure this issue?
Old May 14, 2017 | 03:47 PM
Firebirdmuscle's Avatar
It could be a few issues. It could be that the fueling is off in those particular spots and is swinging enough to cause the surge. Could be to much timing in it also
