Need Help. On Vacation and motor is going NUTS!!!
Problem: Falling flat on acceleration and cruising. WOT runs like a raped ape. Sometimes while driving it will correct and run great. But only for seconds. Then back to a bog.
At idle it sounds great. Fuel pressure is around 55. On throttle it jumps to 60. I've replaced all the plugs. MAF is 4 months old and cleaned. Pulled codes and it showed a knock sensor issue. Pulled the intake and replaced both knock sensors and harness. Went ahead and replaced the intake with a cleaner one. While in it I cleaned the TB really well. Fired it up and thought we had it whooped. No dice. After driving down the road it is back. All the coils are firing.
I hooked it up to a Snapon scanner and the only thing it is showing is an O2 sensor reading on the passenger side that is all over the place. From 200 to 800. Constantly bouncing. I plan on changing this out tomorrow. If this doesn't fix it, where should I look next? I filled it with premium and threw a can of seafoam in it, hoping it would help.
Any help would be greatly appreciated.
Sensor should bounce from 200-800 like crazy.
When you hit WOT, it ignored oxygen sensors and fuels according to tables. "Open loop".
Light acceleration and cruising, if sensor is always reading 900+, the computer tries to keep cutting fuel. 450 is stoich. Higher is rich, lower is lean. The ECU expects it to switch rich to lean to rich to lean constantly.
