LS2 no start error P0335
Old May 31, 2017 | 10:49 AM
csouth's Avatar
Default LS2 no start error P0335
I'm getting a P0335 on my motor that i had running in the past, but no will not start. I did remove my harness and reconnect it when i brought the ECU inside the car. I'm wondering if something happened to the connector? I want to check the voltage which i read should be 5v for a 58x motor? Do I need to check in the key on position or during actual cranking? Right now no RPM's are registering in HPtuners. Any feedback is greatly appreciated.
