flex fuel timing
Old Jun 19, 2017 | 11:19 AM
patSS/00's Avatar
Default flex fuel timing
I'm thinking of adding flex fuel, so I looked at a couple of 02 suburban tunes. In particular, the flex fuel spark table - noticed that for lower cylinder airmass (below about .44) the timing is retarded, for high airmass the timing is advanced. Why is that? Does that mean you get worse performance at part throttle with ethanol?
Old Jun 19, 2017 | 12:00 PM
T/A KID's Avatar
Burn rate of fuel...
OEM does it correctly... just needs tweaked
Old Jun 19, 2017 | 01:43 PM
subeone's Avatar
exactly what T/A kid said. The laminar flame speed of ethanol is higher than gasoline. 27 cm/s for gasoline and 42 cm/s for ethanol. This indicates that less ignition timing is needed at light loads and hence why timing is pulled.
Old Jun 19, 2017 | 08:11 PM
rpturbo's Avatar
Would you be willing to expand on this? I am going to start tuning on a Flex setup soon, and any pointers would be greatly appreciated!
