Help with sorting out stand alone harness
Relay 1
White 86 runs to red pin 9 fuel pump relay control
Yellow 87 runs to spare cut yellow wire that's hanging down
Blue 30 runs to fuse two green
Black 85 runs to-
red pin 24 and tps sensor pin c
blue 60 BLK 452 Low Reference TPS Pin “B”
Relay 2
White 86 runs to fuse 1 green
Yellow 87 runs to fuse 1 green
Blue 30 runs to spare cut blue wire that's hanging down (ignition on 12+?)
Black 85 runs to green fuse 1
In the attached pics fuse 1 is the yellow to the right and fuse 4 is the the green furthest to the left. The two orange writes that are cut and hanging feed the fuse panel.
